madcowscarnival Posted November 10, 2022 Share Posted November 10, 2022 Hey all. I'm trying to figure out a roof layout for a builder's hand drawn plan. There is a 2nd floor at the front of the house, the rear pitch extends from that 2nd floor ridge to the first floor wall at the top plate. The rear plane (a 10:12) is "located" on the second floor. There is a breakfast nook extending from the rear wall of the house. I want to try and make the valley from the 2nd floor plane "attach" to the valley on the 1st floor rear gable using the join planes tool. I've attached. That's not a particularly critical area, but demonstrates the issue I'm having. The entire purpose of this is to figure out the rather messy area on the right side of the plan without him just going in and overlaying crickets as needed. Thank you all. Untitled 1.plan Link to comment Share on other sites More sharing options...
mtldesigns Posted November 10, 2022 Share Posted November 10, 2022 Have you tried putting all the roofs on the same level? If I am understanding the issue... determine the level you want all planes, select and move each accordingly with the arrows highlighted on the attached. It wont mess your model up either.. I did not open your model to see if this was the issue.. Link to comment Share on other sites More sharing options...
madcowscarnival Posted November 10, 2022 Author Share Posted November 10, 2022 I had not tried that, but will try and see what happens. I did just find out that those tools work in "ortho" independently of what "plan" floor they are on. Very nice. It seems like it solves the problem pretty well, but maybe not with the correct method. Link to comment Share on other sites More sharing options...
SNestor Posted November 10, 2022 Share Posted November 10, 2022 Is this what you are trying to achieve? Link to comment Share on other sites More sharing options...
madcowscarnival Posted November 10, 2022 Author Share Posted November 10, 2022 SNestor, yes. Now I have to get the builder in here to sit down and look through it. Thank you. Link to comment Share on other sites More sharing options...
Steve_Nyhof Posted November 13, 2022 Share Posted November 13, 2022 On 11/10/2022 at 6:06 PM, madcowscarnival said: I had not tried that, but will try and see what happens. I did just find out that those tools work in "ortho" independently of what "plan" floor they are on. Very nice. It seems like it solves the problem pretty well, but maybe not with the correct method. You just move them up or down to make your joins, then move them back to the floor where you want them to display in your plan. Link to comment Share on other sites More sharing options...
