Roof thickness
ElizGuseva
Hi!
Faced with a problem. I made a roof for my new project, but I couldn't find how to adjust its thickness.
There is no training video on this topic, only roof configurations.
I tried changing some of the settings, but I still can't get to the 1.5' roof thickness form.
Please tell me if it is possible and if so how to do it
I am using Chief Architect Premier X12 (64 bit)
Thank you!
The structure panel is where you specify depth (thickness) of sheathing and framing.  The surface panel is where you can do all your buildup of paper, membrane, rooftop insulation, and roofing weather surface (shingles, metal, TPU, etc.).
Back in the structure panel, all the elements under Roof Size is where you can access and change subfascia and fascia size to be where you need things so soffit and trim all looks like you want.
