Large AutoCAD file
capitaldesigns
Hi Mike,
It is actually not that bad on my machine, ( which is getting outdated ).  What are you running ?
Unfortunately Chief does not handle AutoCad files very well.  So replace anything you can with Chief content or maybe try turning off layers that are not in use.  If that does not work it might be time for a new computer.
I have a test file right now with one PDF and some imported CAD contour lines, but not as many as yours and it is much slower than your file.  6-7 seconds to select a contour line which is not even a contour line but a Standard Polyline like yours.
15 minutes ago, capitaldesigns said:
I have a Dell XPS. It's around 3 years old.
Humm...    Newer than mine.   Can you post the specs ?  Do you have an SSD ?
Perhaps you have other stuff running or even shutting down and restating may help or a M$ update running in the background maybe.
