Glitch with bow window, ceiling above lowered.
keithsmessina
I'm having an issue that when I lower the ceiling above a bow window, it drops the whole floor's ceiling height. After it does that, it then automatically unchecks the checkbox for lowered ceiling in the bow window settings. Anyone run into that issue?
Now when I open the file, each time I go into the window settings and then click on the "has lowered ceiling" checkbox, when I hit OK, it lowers the entire floor's ceiling. The checkmark will be unchecked if you go back into the window's options after that. It will incrementally lower the ceiling each time you do this.
test.plan
If you are trying to lower the ceiling in a camera view, maybe you accidently selected the room instead of the bay window?  Pay attention to what the status bar says because it will tell you what you have selected.
If you are trying to lower the ceiling in the bay window dialog, and it changes the whole plan, then there might be something messed up in your plan.  I have no idea what though since I have never had that happen.
