Jambruins Posted October 18, 2022 Share Posted October 18, 2022 Why is my wall overlapping my other wall? See picture. Link to comment Share on other sites More sharing options...
mtldesigns Posted October 18, 2022 Share Posted October 18, 2022 1 hour ago, Jambruins said: overlapping my other wall You will see this a lot, ESPECAILLY at railing or invisible wall to a normal wall intersections at a corner. One of top things IMO that needs fixed. You can fix it manually by using the "Edit Walls Layer Intersection" icon. Bottom toolbar, has a two blue walls connecting with a red arrow. You will need to pick each wall most likely, adjust by dragging the grips. 1 1 Link to comment Share on other sites More sharing options...
glennw Posted October 18, 2022 Share Posted October 18, 2022 My guess is that you have the layer Walls, Main Layer Only selected. Those 3 wall layers are probably the main wall layers. Link to comment Share on other sites More sharing options...
