pwrd90 Posted October 15, 2022 Share Posted October 15, 2022 Hi team, I'm trying to export my layouts file to .pdf using the print dialogue in Chief X14, and for some reason one of the images is coming out larger and all of the text in the layout pages is being italicized, rather than printing in the same way it is shown on the layouts screen. I have tried Microsoft Print to PDF and that fixed the text problem, but not the image problem. It also seems to take a very long time to print to PDF. Can someone shed some light on this? Images attached for clarity, thanks. Link to comment Share on other sites More sharing options...
Chopsaw Posted October 16, 2022 Share Posted October 16, 2022 What PDF print driver did you actually use ? This seems to have some similarities to another situation that came up recently. Not sure exactly what to think about the text but that could be dependent on the PDF print driver as well for the embedded font. Link to comment Share on other sites More sharing options...
pwrd90 Posted October 18, 2022 Author Share Posted October 18, 2022 Hi Chopsaw, I was using the Chief Architect native pdf print function. I am not aware of being able to change any of the functions of that. I have managed to solve the image issue, the image box was larger than the displayed image, which for some reason allowed it to move when printed. The font issue is prevailing though and I have not found any option aside from using the Microsoft Print to PDF function, which takes a ridiculously long time to process. I have also noted that the issue only appears to affect the font when text is directly on the layout page, the font applied to the plans that are displayed on the layout page have the font printed correctly. It would be great to solve this as taking 15-20 minutes to process the plans using the Microsoft Print to PDF is maddening when the Chief printer takes less than a minute to do the same task. Link to comment Share on other sites More sharing options...
Chopsaw Posted October 18, 2022 Share Posted October 18, 2022 1 hour ago, pwrd90 said: I have also noted that the issue only appears to affect the font when text is directly on the layout page, the font applied to the plans that are displayed on the layout page have the font printed correctly. That in combination with using The "Chief Architect Save As PDF", I would have to say it is a Chief problem. Have you contacted tech support ? Also does it happen with other more common fonts ? Link to comment Share on other sites More sharing options...
pwrd90 Posted October 18, 2022 Author Share Posted October 18, 2022 13 minutes ago, Chopsaw said: That in combination with using The "Chief Architect Save As PDF", I would have to say it is a Chief problem. Have you contacted tech support ? Also does it happen with other more common fonts ? No I haven't contacted support, I wasn't sure if it was a common issue or not so thought I'd ask here. I haven't tried it with other fonts buy will give that a go next. I guess I'll venture down the support path and see if that sorts it out. Link to comment Share on other sites More sharing options...
KilianDrafting Posted February 24, 2023 Share Posted February 24, 2023 Anyone find a solution to the text problem? I just started having the same problem. Picture attached. The PDF on left was printed last night on home computer. PDF on right printed this morning on office computer. Both using the same settings in X14. I did download X15 Beta yesterday on the office computer, not sure if that affects anything in X14. It appears the Chief Blueprint text spacing is getting squeezed, both on the text and dimensions. I tried a different pdf writer and it fixed the problem, but it slower. Link to comment Share on other sites More sharing options...
Chopsaw Posted February 24, 2023 Share Posted February 24, 2023 4 hours ago, KilianDrafting said: Anyone find a solution to the text problem? I just started having the same problem. Picture attached. The PDF on left was printed last night on home computer. PDF on right printed this morning on office computer. Both using the same settings in X14. I did download X15 Beta yesterday on the office computer, not sure if that affects anything in X14. It appears the Chief Blueprint text spacing is getting squeezed, both on the text and dimensions. I tried a different pdf writer and it fixed the problem, but it slower. I would give that a try in X15 and see if you have the same issue. If so please send it in. There have been a few changes in the Chief Blueprint font in previous versions but not sure about X15 yet. Maybe check the PDF file properties for embedded font information and compare them. Link to comment Share on other sites More sharing options...
KilianDrafting Posted February 24, 2023 Share Posted February 24, 2023 Tried it in X15 and the problem is gone. Re-tried in X14 and still have the same issue with the text. I checked some other PDFs I created earlier this week in X14 and they show correctly. Not sure what happened in the last 24 hours that would cause the issue. Link to comment Share on other sites More sharing options...
