ChiefUserHeather Posted October 6, 2022 Share Posted October 6, 2022 I just download the X14. When it opens up a new template - The Electrical default is open first. How can it be changed to 1/4" scale working layer set for all templates? Chief Architect 14 user. Link to comment Share on other sites More sharing options...
ChiefUserHeather Posted October 6, 2022 Author Share Posted October 6, 2022 That not work Link to comment Share on other sites More sharing options...
ChiefUserHeather Posted October 6, 2022 Author Share Posted October 6, 2022 I used a floor plan templet - change all the settings. Then I saved as a template. Still did not work Link to comment Share on other sites More sharing options...
DBCooper Posted October 6, 2022 Share Posted October 6, 2022 Try going into your preferences and using the "reset templates" tool. This will make sure you are using the factory installed templates. Then go to your new plan preferences and make sure you are using the "residential template.plan". This will make sure that you start new plans with the default installed template. If that doesn't solve your problems, then you might want to contact support. There is also lots of info about templates here: https://www.chiefarchitect.com/support/category/271/templates.html Link to comment Share on other sites More sharing options...
Kbird1 Posted October 7, 2022 Share Posted October 7, 2022 2 hours ago, ChiefUserHeather said: I used a floor plan templet - change all the settings. Then I saved as a template. Still did not work When you saved it, did you also check the box to make it the new Default Template Plan? https://www.chiefarchitect.com/support/article/KB-00463/creating-and-using-a-plan-template.html https://www.chiefarchitect.com/support/article/KB-00333/restoring-the-default-plan-and-layout-template.html https://chieftalk.chiefarchitect.com/topic/18908-signature-here-at-chief-talk/?tab=comments#comment-155662 M. Link to comment Share on other sites More sharing options...
