wpdesigninc Posted September 30, 2022 Share Posted September 30, 2022 Using X14. How do you create a miter corner when adding trim with a 3D molding line? See attached photos. I have some floating walls in a kitchen which seams to not automatically apply my molding profiles to the plan to these walls. I have added the trim manually but can not figure out how to create mitered corners. Please advise. Thanks in advance! Link to comment Share on other sites More sharing options...
glennw Posted September 30, 2022 Share Posted September 30, 2022 You need to use a multi segment molding polyline that bends 90deg around the corner. It looks like you have used individual molding lines on each side. 1 Link to comment Share on other sites More sharing options...
DBCooper Posted September 30, 2022 Share Posted September 30, 2022 Quote I have some floating walls in a kitchen which seams to not automatically apply my molding profiles to the plan to these walls. I have added the trim manually but can not figure out how to create mitered corners. You might not even need to draw molding polylines. Draw an invisible wall to connect your "floating" walls to the other walls in your room and it should get the room molding. Link to comment Share on other sites More sharing options...
