GeneDavis Posted September 14, 2022 Share Posted September 14, 2022 On an entry porch, look at what I get. That is a wall with exterior finish both sides getting chopped not to its framing but to its sheathing, by the intersecting railing wall, which is invisible. I show how I tried to fix it by editing the layer positions at the intersection. Link to comment Share on other sites More sharing options...
robdyck Posted September 14, 2022 Share Posted September 14, 2022 Gene, it looks like you may have overlooked posting the plan. Link to comment Share on other sites More sharing options...
GeneDavis Posted September 14, 2022 Author Share Posted September 14, 2022 Here is the plan file. Spread Eagle Shed.zip Link to comment Share on other sites More sharing options...
Solution HamlinBC Posted September 14, 2022 Solution Share Posted September 14, 2022 If you delete your invisible railing wall, and put in a room divider it goes away. Hope that helps Link to comment Share on other sites More sharing options...
robdyck Posted September 14, 2022 Share Posted September 14, 2022 Ditto, room divider, uncheck railing. Link to comment Share on other sites More sharing options...
GeneDavis Posted September 14, 2022 Author Share Posted September 14, 2022 Ahh! The ins and outs of wall-end joint behavior. Someone could write a book on this. Thanks, to my Chieftalk brethren from the far northwest. Problem solved. Link to comment Share on other sites More sharing options...
PMMully Posted September 14, 2022 Share Posted September 14, 2022 Sometimes the doorway in the wall works very well, others not. I found that it works very well in smooth/stucco applications. When I had the siding, I cut to a post2beam and removed the start/end and it worked well. Seems like every condition is different and rendering engine can not interpret every situation as we want it. Link to comment Share on other sites More sharing options...
