Setting the Terrain Perimeter Default
Bill_Nelson
21 hours ago, Bill_Nelson said:
Can the terrain perimeter be set to a default of 12" below your foundation wall so you're not always having to adjust it when your drawing plans?
I am using C.A. X12
Thanks,
Bill
No as mentioned Chief does this dynamically based on Floor structure and adding 6 - 8" for ground clearance that is require by code in most areas.
 https://www.chiefarchitect.com/support/article/KB-00938/how-the-height-of-floors-relate-to-the-height-of-the-terrain.html
