GeneDavis Posted August 29, 2022 Share Posted August 29, 2022 Plan attached. The whole thing about roof cutting wall and pony walls and attic walls is a mystery to me when it comes to this arrangement. I have tried for hours to get this cleaned up, but cannot. It is 2x6 with siding above the roofs, 2x4 sheetrock below. What's so hard about that? The inside faces of the above and below wall are supposed to align, of course. And then there is the wall corner bite. What's that about? Glen Road Top End.plan Link to comment Share on other sites More sharing options...
robdyck Posted August 29, 2022 Share Posted August 29, 2022 13 hours ago, GeneDavis said: The whole thing about roof cutting wall and pony walls and attic walls is a mystery to me when it comes to this arrangement. I have tried for hours to get this cleaned up, but cannot. In Chief, try to model it how it will be built. For the area to the left of the Unspecified (Bedroom?), you want the 2nd floor exterior cheek wall to extend inward to the ceiling break line. This means the interior partition should be split at that junction and then reverse layers of one of those portion to prevent re-joining. Then decide if the cheek wall will be cut by the roof OR if it will be a pony wall, split by the roof. If the latter, then select the lower wall type in the Roof tab of the Wall Spec. dialog. If the former, the uncheck Lower Wall Type. For the attic wall, I would uncheck 'Roof Cuts Wall at Bottom' and manually drag the wall into position in Elevation view. Chief will automatically build this wall wrong unless you split it into 2 portions (one for above the cheek wall and one that extends from the end of cheek wall to the ridge). Link to comment Share on other sites More sharing options...
robdyck Posted August 29, 2022 Share Posted August 29, 2022 For the 2nd Floor Bath cheek wall, you'll need to use a 2x6 interior wall for the lower portion because Chief will extend the floor platform out to the exterior of the 2x6 Siding wall (so it will show through from the main floor. Again, 2nd floor cheek wall should stop at the ceiling break line. This wall should NOT be cut by the roof. And, on the main floor, you'll need to pull the ceiling plane back so it does not cut that exterior cheek wall. Link to comment Share on other sites More sharing options...
GeneDavis Posted August 29, 2022 Author Share Posted August 29, 2022 Thanks, Robert. I have never ever wasted the time on dormer cheeks in a Chief plan I have on this one, and it is still not right. The upstairs bathroom cheek wall is kicking my butt. The other two are done. Not quite right, but done. Glen Road stripped.zip Link to comment Share on other sites More sharing options...
Solution robdyck Posted August 30, 2022 Solution Share Posted August 30, 2022 16 hours ago, GeneDavis said: The upstairs bathroom cheek wall Hi Gene, select that wall and uncheck Pony Wall. It will then rebuild correctly and Chief will rebuild it as a Pony Wall. Link to comment Share on other sites More sharing options...
GeneDavis Posted August 30, 2022 Author Share Posted August 30, 2022 Thanks, Robert! That did it. Link to comment Share on other sites More sharing options...
