Bump-out window
Skip_D
Hi All,
I'm looking for suggestions on how to illustrate a bump-out window.  This would be similar to a 'box bay' but without the side windows.  I realize using the box bay I can delete the side windows but am having difficulty add more than one window on the outer side.  I've tried using a pony wall and defining the upper thicker ... that works okay but the floor assembly pierces the lower wall too align with the upper frame line ... not good.
These are pretty common windows solutions so i have to believe there's a better way.
Any/all suggestions are appreciated.
thanks,
Skip
In X14, you could start with a box window and explode it.  Then you can add more windows to the outside wall.
In X13, you might be able to create a room for the bumpout and adjust the floor height and get better results.
