GP202256 Posted August 23, 2022 Share Posted August 23, 2022 How do I get 2x10 decking joists to be automatic when building decks? Link to comment Share on other sites More sharing options...
rgardner Posted August 23, 2022 Share Posted August 23, 2022 1 minute ago, GP202256 said: How do I get 2x10 decking joists to be automatic when building decks? Use a template plan that has it set in the deck room default. Link to comment Share on other sites More sharing options...
GP202256 Posted August 23, 2022 Author Share Posted August 23, 2022 So I cannot reset the plan that I am in currently? Link to comment Share on other sites More sharing options...
DBCooper Posted August 23, 2022 Share Posted August 23, 2022 You can have different sized deck joists for each deck in your plan. Select the deck and open the room dialog. Look at the deck page. Link to comment Share on other sites More sharing options...
rgardner Posted August 24, 2022 Share Posted August 24, 2022 4 hours ago, GP202256 said: How do I get 2x10 decking joists to be automatic Answering your OP you set it up in your template plan as oob Chief uses 2x8. 4 hours ago, GP202256 said: So I cannot reset the plan that I am in currently? Answering your new question you need to change that deck rooms floor structure as @DBCoopershows above. btw simply responding will not let anyone know you had a further question. You need to quote that person or tag them by using @ @GP202256so it will let them know. Link to comment Share on other sites More sharing options...
