PIR-Designs Posted August 23, 2022 Share Posted August 23, 2022 I recently downloaded X-14. Normally when I'm going to assign a color to a cabinet or whatever, I can type in the color in the library materials, and I see lots of options. Sometimes the color is related to a tile, which of course, I cannot use on a cabinet. But when I do a simple as search such as "brown", I'm seeing these little "caution" signs that say texture is missing. Never seen that on any other version. I tried updating catalogs, etc. But the photo below is what I'm seeing. Is there something else I need to do to make these colors show up in the search browser? Thank you. Lauren Link to comment Share on other sites More sharing options...
Solution robdyck Posted August 23, 2022 Solution Share Posted August 23, 2022 You probably need to update the Cactus Stone catalog. That 'Drfit' folder no longer exists. Also, you'll need to replace that material in any plan using it, or simply assign a texture file. You can do this by copying the file path from a similar material. That particular material should be in a different folder...see image below. Link to comment Share on other sites More sharing options...
Kbird1 Posted August 23, 2022 Share Posted August 23, 2022 Try deleting bad folders and redownload the X14 Libraries, my guess would be you have deleted some folders eg old Versions' Data Folders and chief can no longer find them. Mick. Link to comment Share on other sites More sharing options...
PIR-Designs Posted August 23, 2022 Author Share Posted August 23, 2022 46 minutes ago, Kbird1 said: Try deleting bad folders and redownload the X14 Libraries, my guess would be you have deleted some folders eg old Versions' Data Folders and chief can no longer find them. Mick. Hi Mick, I've never deleted any folder in CA. I'm not sure how to find specific folders that contain all of these. They were things that came with the original core catalogs. So if I start deleting folders that may contain these "colors with texture" I might end up deleting something I shouldn't. But thank you so much for your response. Greatly appreciated. Lauren Link to comment Share on other sites More sharing options...
PIR-Designs Posted August 23, 2022 Author Share Posted August 23, 2022 3 hours ago, robdyck said: You probably need to update the Cactus Stone catalog. That 'Drfit' folder no longer exists. Also, you'll need to replace that material in any plan using it, or simply assign a texture file. You can do this by copying the file path from a similar material. That particular material should be in a different folder...see image below. I have no idea what the Cactus Stone catalog is. I don't recall downloading that in previous versions. I'll check with support for a solution that might not involve me jacking up something I shouldn't. LOL! Thank you for your response. Really appreciated. Link to comment Share on other sites More sharing options...
PIR-Designs Posted August 23, 2022 Author Share Posted August 23, 2022 3 hours ago, robdyck said: You probably need to update the Cactus Stone catalog. That 'Drfit' folder no longer exists. Also, you'll need to replace that material in any plan using it, or simply assign a texture file. You can do this by copying the file path from a similar material. That particular material should be in a different folder...see image below. I just went and looked at the colors again, I see that you were referring to the manufacturer that had that color I had clicked on. So it must have been something downloaded, like you said. But I can't delete it while it's in the search area. Even after we install catalogs, are they still being accessed though the folder on our computers from where they were downloaded? I mean, where would I delete these from? And if I do, I won't be able to access them if I use an older version, right? Link to comment Share on other sites More sharing options...
Kbird1 Posted August 24, 2022 Share Posted August 24, 2022 26 minutes ago, PIR-Designs said: I just went and looked at the colors again, I see that you were referring to the manufacturer that had that color I had clicked on. So it must have been something downloaded, like you said. But I can't delete it while it's in the search area. Even after we install catalogs, are they still being accessed though the folder on our computers from where they were downloaded? I mean, where would I delete these from? And if I do, I won't be able to access them if I use an older version, right? Just right Click the Catalog in the Library and >Delete Catalog Link to comment Share on other sites More sharing options...
PIR-Designs Posted August 24, 2022 Author Share Posted August 24, 2022 22 hours ago, robdyck said: You probably need to update the Cactus Stone catalog. That 'Drfit' folder no longer exists. Also, you'll need to replace that material in any plan using it, or simply assign a texture file. You can do this by copying the file path from a similar material. That particular material should be in a different folder...see image below. THAT WAS IT! YAY! So what I figured out that happened was that this time when I downloaded and installed X14, I put it in a different location on a different drive. It was trying to find stuff that was on my old versions on the C drive. So I went to the Cactus Stone location for X11, then while in X14, I "imported" the X11 Cactus Stone catalog... IT WORKED! Brilliant! Thanks S0 much! Link to comment Share on other sites More sharing options...
