TonytheArcht Posted August 17, 2022 Share Posted August 17, 2022 Hello. When I add a window or door schedule, the labels are automatically generated but smaller than what I would prefer. How can the size be increased? CA Premiere X14. Link to comment Share on other sites More sharing options...
Solution glennw Posted August 17, 2022 Solution Share Posted August 17, 2022 Try here: 2 Link to comment Share on other sites More sharing options...
OldBarnDesign Posted August 17, 2022 Share Posted August 17, 2022 Hi Tony, just curious how you offset the window labels from the window itself? For me the labels always appear on top of the window? Thanks! Link to comment Share on other sites More sharing options...
rlackore Posted August 17, 2022 Share Posted August 17, 2022 32 minutes ago, OldBarnDesign said: Hi Tony, just curious how you offset the window labels from the window itself? For me the labels always appear on top of the window? Window Specification>Label>Plan View Position and Orientation This setting can be adjusted on a per-window basis; it can also be set in the Defaults. Or, select the Window and drag the Label into position using the Label's edit handle. 1 Link to comment Share on other sites More sharing options...
OldBarnDesign Posted August 17, 2022 Share Posted August 17, 2022 Thank you! Link to comment Share on other sites More sharing options...
TonytheArcht Posted August 22, 2022 Author Share Posted August 22, 2022 On 8/16/2022 at 10:08 PM, glennw said: Yes, Glenn, this worked fine. Thank you! On 8/16/2022 at 10:08 PM, glennw said: Try here: Link to comment Share on other sites More sharing options...
TonytheArcht Posted August 22, 2022 Author Share Posted August 22, 2022 On 8/17/2022 at 8:15 AM, OldBarnDesign said: When you zoom in there's a couple of control points. The smaller one in the center allows you to relocate the label. On 8/17/2022 at 8:15 AM, OldBarnDesign said: Hi Tony, just curious how you offset the window labels from the window itself? For me the labels always appear on top of the window? Thanks! Link to comment Share on other sites More sharing options...
