Lighthouse Posted August 16, 2022 Share Posted August 16, 2022 I'm working on some very close in details, trying to dimension to 1/64". I have my full size dimension default set to 1/16 for text and 1/32 for arrow. But when I measure something, the screen display of the hash mark on the dimension is more like 1/2", and kind of covers what I'm trying to see. Is there some way to control the display size of dimensions besides editing the dimension defaults? thanks X12 Link to comment Share on other sites More sharing options...
rgardner Posted August 16, 2022 Share Posted August 16, 2022 5 minutes ago, Lighthouse said: the hash mark on the dimension Are you referring to the hash (arrow) for the dimension string? Change the default arrow size if that is what you are referring to. But you need to give more info otherwise. Link to comment Share on other sites More sharing options...
Lighthouse Posted August 16, 2022 Author Share Posted August 16, 2022 yes, the hash mark that determines the end points on a dimension. I have made it 1/32 in the dimension default but it still appears on the screen as about 1/4", I can't seem to get it any smaller Link to comment Share on other sites More sharing options...
rgardner Posted August 16, 2022 Share Posted August 16, 2022 21 minutes ago, Lighthouse said: yes, the hash mark that determines the end points on a dimension. I have made it 1/32 in the dimension default but it still appears on the screen as about 1/4", I can't seem to get it any smaller You keep calling it a hash mark which is the type of "ARROW" that is selected for that dimension default. Arrows are not controlled by the text. You need to change the "ARROW" size. Link to comment Share on other sites More sharing options...
Joe_Carrick Posted August 16, 2022 Share Posted August 16, 2022 You might also want to change the Minimum Display Size for Dimensions in Preferences> Appearance. That is normally set to 8 Pixels - I prefer 4 or 5 Link to comment Share on other sites More sharing options...
