winterdd Posted August 16, 2022 Share Posted August 16, 2022 Anyone know how to rotate the material on a panel/knee wall. I used a railing wall to create the screened porch. Each wall is one segment but there is a variation on the beadboard paneling I am using as well (circled). I want to clean this up and rotate the beadboard 90 deg. Link to comment Share on other sites More sharing options...
ericepv Posted August 16, 2022 Share Posted August 16, 2022 You should be able to do that with the Define Material tool (the rainbow symbol in your toolbar). Set the angle in the Texture section. You can also adjust the height with the Vertical Offset tool. 1 Link to comment Share on other sites More sharing options...
winterdd Posted August 16, 2022 Author Share Posted August 16, 2022 13 minutes ago, ericepv said: You should be able to do that with the Define Material tool (the rainbow symbol in your toolbar). Set the angle in the Texture section. You can also adjust the height with the Vertical Offset tool. Worked perfectly. A symbol I never use. Now I Know. Link to comment Share on other sites More sharing options...
Gawdzira Posted August 16, 2022 Share Posted August 16, 2022 A lot of the materials similar to that one, I end up with a copy in my plan called "Whatever Material_Rotate" 1 Link to comment Share on other sites More sharing options...
