Sign in to follow this
jcaffee
'splain Me Why There Are Four Tcp Connections Open In X7?
Why is CAX7 keeping four TCP connections open during a session? (X6 had one, and I chalked that up to lazy developers not killing the process after license check--but four?)  Does the Deathstar really need durable access while I'm using the software?  To what end?
jon
for the activate/deactivate button? though that should just "dial home" when needed ,other than that I thought it only called home once every two weeks to re-register.
how are you checking?
MS Resource Monitor>Network>TCP Connections.  This shows all active connections in real time.
jon
Maybe each window runs as a separate process? How many windows do you have open?
4 here too , even if minimised , if the comp. sleeps however they go away....(was just out of the Office)   strange behaviour....
    27620
    edos301
    edos301
