Jonathan3891 Posted July 28, 2022 Share Posted July 28, 2022 I'm having an issue where the deck is clipping the exterior wall. How do I fix this without messing up the deck framing I did manually? Remodel_Plan.zip Link to comment Share on other sites More sharing options...
CharlesVolz Posted July 28, 2022 Share Posted July 28, 2022 Rebuild the deck framing. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted July 28, 2022 Share Posted July 28, 2022 Your deck wall is just out of alignment by about 1/16". Move it over so that its right on line with the adjacent wall and you should be good. Link to comment Share on other sites More sharing options...
Jonathan3891 Posted July 28, 2022 Author Share Posted July 28, 2022 7 hours ago, solver said: @solveryou are the man! I knew the deck framing was the issue, but every time I tried to pull it away from the wall it would snap back. That's a neat trick with the room divider. Link to comment Share on other sites More sharing options...
