ADallas Posted July 26, 2022 Share Posted July 26, 2022 I've been editing and re-editing a model, taking one physically based (ray trace) image after another, and I'm seeing what seems like sunlight coming in under one wall. This is likely due to something one-off about the wall or room spec, but I have checked both. This is a "standard" Interior-4 partition. The full .plan file is way too complicated to share. I'm wondering if anyone else has seen this effect and if there is a simple solution. I don't mind modeling something "backstage" to eliminate the light leak. (BTW, I searched the forum for "physically based" OR "ray trace" and got 0 results before posting.) Link to comment Share on other sites More sharing options...
rgardner Posted July 26, 2022 Share Posted July 26, 2022 Do you have a foundation built? Same concept as the roof if you have light bleed at the top of the wall. Close it all off. 1 Link to comment Share on other sites More sharing options...
Alchemyjim Posted July 26, 2022 Share Posted July 26, 2022 Same problem here. I can't get this bleed to go away above the roof beams. I even laid a giant polyline solid over the roof surface to no avail. 1 Link to comment Share on other sites More sharing options...
ADallas Posted July 26, 2022 Author Share Posted July 26, 2022 (edited) Thanks, Ryan. I had a foundation, but I hadn't built the floor or wall framing. However, it didn't help. I "poured" a 6" concrete wall behind the wall that's leaking and extended it well into the terrain--2001: A Space Odyssey obelisk-style--and I still get this light effect. I'm starting to think that it's a reflection off the bright white baseboard. So I moved the obelisk to mostly cut off light entering the room from behind the camera and it still leaks under the baseboard. Edited July 26, 2022 by ADallas Additional testing. Link to comment Share on other sites More sharing options...
robdyck Posted July 26, 2022 Share Posted July 26, 2022 3 minutes ago, ADallas said: I'm starting to think that it's a reflection off the bright white baseboard. It's not that. It's either an issue with the model or your render / lighting settings. You'd have to post the plan in order for someone to help troubleshoot this. 1 Link to comment Share on other sites More sharing options...
ADallas Posted July 26, 2022 Author Share Posted July 26, 2022 Thanks, Robert. I'm willing to believe it's the model, because it's the digital equivalent of a posterboard study model, but attempts to block extraneous light haven't worked. I'll look into the render settings--I'm using the defaults as far as I know. Link to comment Share on other sites More sharing options...
rgardner Posted July 27, 2022 Share Posted July 27, 2022 15 hours ago, Alchemyjim said: Same problem here. I can't get this bleed to go away above the roof beams. I even laid a giant polyline solid over the roof surface to no avail. That is a different issue and should have it's own thread. Your beams are going through your roof. Quick way to check if that is the issue is to toggle off sun and see if it goes away. Link to comment Share on other sites More sharing options...
rgardner Posted July 27, 2022 Share Posted July 27, 2022 15 hours ago, ADallas said: Thanks, Ryan. I had a foundation, but I hadn't built the floor or wall framing. However, it didn't help. I "poured" a 6" concrete wall behind the wall that's leaking and extended it well into the terrain--2001: A Space Odyssey obelisk-style--and I still get this light effect. I'm starting to think that it's a reflection off the bright white baseboard. So I moved the obelisk to mostly cut off light entering the room from behind the camera and it still leaks under the baseboard. Quick check to see if its light bleed or where it is coming from is to toggle sun off. Link to comment Share on other sites More sharing options...
ADallas Posted July 27, 2022 Author Share Posted July 27, 2022 9 hours ago, rgardner said: Quick check to see if its light bleed or where it is coming from is to toggle sun off. Good idea! Turning off the sun turns off the bleed. Link to comment Share on other sites More sharing options...
rgardner Posted July 28, 2022 Share Posted July 28, 2022 1 hour ago, ADallas said: Good idea! Turning off the sun turns off the bleed. So that means that something is amiss with the model. A wall is not aligned maybe? foundation wall to exterior of wall or??? Link to comment Share on other sites More sharing options...
ADallas Posted July 28, 2022 Author Share Posted July 28, 2022 Well, here's a simple test plan. I created a box and divided it into two rooms with a zig zag interior partition. The room on the left has two windows and the sunlight leaks into the windowless room on the right. I'm beginning to suspect a bug with Chief's ray tracing algorithm. Light bleed test.plan Link to comment Share on other sites More sharing options...
