Rashid_Garuba Posted January 20, 2015 Share Posted January 20, 2015 I used Chief from V9 to X1,.. quit and just came back. I never got to power user stage for various reasons. One that was key I think was keeping Chief out of my way in the very early design stages. I always felt a pressure to make decisions that were frequently undecided too early.. What ended up happening is I would get bogged down with wall types, fixtures.. etc. (I even had to be draw exterior walls clockwise only -- has that changed??) which ultimately meant I ended up much slower than I was in 2d CAD.. So this time I am building my "best practices" wiki so things go better this time. When starting a job I want to start with a 3.5" "design" wall (main layers only) and specify no defaults. (when I use layered walls I have to zoom in a lot to avoid extra layers with the measure tool) I simply want a piece of paper that happens to be to scale. Do others start this way? Will I run into issues later selecting same type and THEN setting defaults? The room planner uses this basic principle but I haven't used it much... Thanks Link to comment Share on other sites More sharing options...
joey_martin Posted January 20, 2015 Share Posted January 20, 2015 I always start with real paper and pencil. I can't sit at a computer and "design". I'm too old school I guess. Every plan I have designed..ever..began on a piece of paper, was developed, and then goes to the computer. I think you will find it easier to develop a really good template plan to start with. Drawing walls in with no layers and no real definition means you will have to go back at some point and re-do them. As for speed, that comes with practice. You are still thinking like a 2D designer. You have to "get with the program" so to speak. Chief Architect is first and foremost a 3D program. There is no way around that, and there are no shortcuts. You need to stop thinking like a CAD user, or you are always going to be in your own way. Link to comment Share on other sites More sharing options...
Rashid_Garuba Posted January 20, 2015 Author Share Posted January 20, 2015 Joey, I still start with paper but transition to PC asap... Old habits die hard but no growth without pain... Is there a setting that makes the tape measure only snap to main layers? Occasionally temporary dims are not enough.. Thanks for your thoughts Link to comment Share on other sites More sharing options...
Gawdzira Posted January 20, 2015 Share Posted January 20, 2015 I put an as built to scale (CADD) on a piece of paper and start layering trace paper. Fast and loose at 1/8 scale to start. Lots of energy lines, notes, scribbles, etc.. Link to comment Share on other sites More sharing options...
