robdyck Posted July 1, 2022 Share Posted July 1, 2022 Using X14, any standard text box that is using a grid to create a table now seem subject to different sizing parameters. I can now only resize the width of these text tables in approx. 3" increments (for 4" tall text). This means they no longer align on one edge (usually the right side) with other stacked text items used in various notes. Does anyone know if there is any sort of setting to allow more refined adjustment of the width of text tables? I've attached a sample plan. text width issue x14.planFetching info... Link to comment Share on other sites More sharing options...
Renerabbitt Posted July 1, 2022 Share Posted July 1, 2022 On 7/1/2022 at 1:54 PM, robdyck said: Does anyone know if there is any sort of setting to allow more refined adjustment of the width of text tables? I've attached a sample plan Expand ...In the meantime, set the width to your desired width in the dbx and re-center it. I used to know why it does this but it is escaping me right now 1 Link to comment Share on other sites More sharing options...
robdyck Posted July 1, 2022 Author Share Posted July 1, 2022 On 7/1/2022 at 3:45 PM, Renerabbitt said: et the width to your desired width in the dbx and re-center it Expand You are the man Rene! The width is available for a text with a grid and for a text box without a grid (at the same time). This allows me to reset many text box widths at once. Thank you!! Link to comment Share on other sites More sharing options...
Alaskan_Son Posted July 2, 2022 Share Posted July 2, 2022 On 7/1/2022 at 3:45 PM, Renerabbitt said: I used to know why it does this but it is escaping me right now Expand Its being limited by the tab stop limitations which have to be whole numbers. 1 Link to comment Share on other sites More sharing options...
