Help Not Responding (the standard help command)
HomesByDesign
Go to solution Solved by HomesByDesign,
You can review your default browser by looking for "Default Apps" from the start menu. Windows 11 is a bit backwards from other versions. In the Default Apps you select an app and then you choose what file type it should take care of.
Since it is a new computer I would also check that you are current on Windows Updates. You might also add Chief Architect to the "Allow" or "Whitelist" of any antivirus or firewall software you may have installed. If you continue to have trouble with the Help it's a good idea to contact Technical Support so we can get all the details of the problem and help resolve it.
