HomesByDesign Posted June 24, 2022 Share Posted June 24, 2022 In acquiring my my new desktop with Win11 the Chief "Help" function does not respond. All other web functions work as expected. Has anyone experienced similar with an upgrade? I can't find a default browser setting to review. Thanks R, Link to comment Share on other sites More sharing options...
DavidJPotter Posted June 24, 2022 Share Posted June 24, 2022 No, call Tech Support for help to straighten that out. DJP Link to comment Share on other sites More sharing options...
CarrieS Posted June 24, 2022 Share Posted June 24, 2022 You can review your default browser by looking for "Default Apps" from the start menu. Windows 11 is a bit backwards from other versions. In the Default Apps you select an app and then you choose what file type it should take care of. Since it is a new computer I would also check that you are current on Windows Updates. You might also add Chief Architect to the "Allow" or "Whitelist" of any antivirus or firewall software you may have installed. If you continue to have trouble with the Help it's a good idea to contact Technical Support so we can get all the details of the problem and help resolve it. Link to comment Share on other sites More sharing options...
Solution HomesByDesign Posted June 24, 2022 Author Solution Share Posted June 24, 2022 Problem Solved Windows Task Manager Services Nahimic service Disable Thanks everyone and to David at Tech Support 1 Link to comment Share on other sites More sharing options...
