jarrex Posted June 20, 2022 Share Posted June 20, 2022 Is there a way to do a curved staircase with multiple horizontal railings? Closest thing by default is the Open with Middle Railing, but I need 6 railings, not one. When I created custom millwork, the railing does not bend with the curved stairs: I also tried the tutorial here: But it appears that window treatments do not bend the the curve of the wall I need: Link to comment Share on other sites More sharing options...
yusuf-333 Posted June 25, 2022 Share Posted June 25, 2022 Jarrex here is an other way to do it. convert your panel to a symbol(window) then save that window to your library. draw the curved wall and load that window, it auto curves with your wall. finally delete surfaces and again convert it to a symbol(hope that is milwork) hope that helps. custom pannel window symbol.calibz 1 Link to comment Share on other sites More sharing options...
jarrex Posted June 29, 2022 Author Share Posted June 29, 2022 Thanks Yusuf, that gets me closer, but when I convert it to millwork it inverts the symbol causing the railing to go in the opposite radius. Do you have any idea how to fix this? Link to comment Share on other sites More sharing options...
Joe_Carrick Posted June 29, 2022 Share Posted June 29, 2022 I would do that with a Molding Polyline - change to an arc to match the curved staircase. Then add the number of moldings needed - or just do one molding and mutiple replicate the Molding Polyline vertically. Link to comment Share on other sites More sharing options...
jarrex Posted June 29, 2022 Author Share Posted June 29, 2022 52 minutes ago, solver said: Open the railing symbol and rotate it 180 degrees. Are you referring to the "Rotation" in the "Edit Symbol"? Because no matter what I type in there, it never changes and if I save and re-open it resets to 90 degress: Link to comment Share on other sites More sharing options...
jarrex Posted June 29, 2022 Author Share Posted June 29, 2022 Thanks Solver -- That works great for when the stairs are level, but it seems like if you have a curved stair with both sides railings you run into the issue of you can't use two different symbols for the two different railing sides. Additionally, it looks like the change in elevation also warps the railing design. (This is not the same railing symbol as the other one, but was recreated using the same method). Link to comment Share on other sites More sharing options...
VHampton Posted June 29, 2022 Share Posted June 29, 2022 possible solution... Build (copy and paste) the same set of stairs in a new plan file. Turn off the stringers and risers. Delete every tread. There should be nothing left except for the railings. Convert the remaining railings to a symbol. import the new symbol (3 rail sections) into the active plan file. Raise or lower the imported railing symbol to create the equal spacing as necessary. ...It's pretty close to what you're aiming for. Edit... sorry. Just noticed that you're working in X-13. Either way this method will be the same in any of the latest versions. stairs.plan 1 Link to comment Share on other sites More sharing options...
AspenLeafCH Posted January 7, 2023 Share Posted January 7, 2023 This drove me nuts for a long time but I recently figured out why the program behaves the way it does. First the work around: Change the width of the newel posts to 0" (or 1/64") and the spacing of the newels to something small like 2" (the smaller the number the smoother it will be). Then change the panel type and click OK. The downfall is that you will have to manually add in a post to represent a newel post. The reason why CA acts the way it does: Panels are determined by the distance from newel post to newel post. So if you tell CA that the distance is minimal and then input the width of the newel post as 0 (or 1/64th") the program essentially eliminates the newel post all together. Hope that helps! 1 Link to comment Share on other sites More sharing options...
Dexter1 Posted March 24, 2024 Share Posted March 24, 2024 I tried that but unfortunately I'm still getting straight railing on the curved stairs. Link to comment Share on other sites More sharing options...
