PATTERN
winterdd
What is the correct way to achieve this? I want the board and batten brought down to hide the LVL. I like exposed beams but the owner doesn't. Attached is a screen shot showing the simple dropper tool and the pattern not orientated right and essentially this is not a "real world" way of doing it but it is quicker to get the point across. Note that I used a ceiling beam and edited the size and type to 12' LVL. Would you.....
(a) create a new pattern rotating the board & batten 90 deg?
or
(b) build a polyline solid, give it the B&B material and attach to the side of the LVL?
27 minutes ago, Chopsaw said:
(c) edit the wall polyline to cover the beam. ;)
P.S.  Also we are no longer allowed to have LVL in an exposed situation anyway.
very true....I should have called it an exposed stained/painted beam or something. I knew someone would catch that.
