armfx89 Posted May 29, 2022 Share Posted May 29, 2022 See pics. This is a 1.5 story garage. I set upper wall on both gable ends to balloon frame...but they not being framed correctly. Any idea how to fix this (other than manually editing the wall detail) Link to comment Share on other sites More sharing options...
GeneDavis Posted May 29, 2022 Share Posted May 29, 2022 Post the plan. Should be small enough to not have to compress. Something's up with the attic rooms. 1 Link to comment Share on other sites More sharing options...
rgardner Posted May 29, 2022 Share Posted May 29, 2022 Looks like you have an attic wall that needs to be deleted in the middle that is maybe interfering with the wall below. 1 Link to comment Share on other sites More sharing options...
armfx89 Posted May 29, 2022 Author Share Posted May 29, 2022 Indeed it was the attic space. Room type was set to Attic for both, which was causing the issue. But when I changed it Unspecified, the wall framed correctly!!! But why?? Those two spaces are supposed to be Attic room type.... Link to comment Share on other sites More sharing options...
rgardner Posted May 29, 2022 Share Posted May 29, 2022 20 minutes ago, armfx89 said: Indeed it was the attic space. Room type was set to Attic for both, which was causing the issue. But when I changed it Unspecified, the wall framed correctly!!! But why?? Those two spaces are supposed to be Attic room type.... Probably something to do with the ceiling definition of the room. Link to comment Share on other sites More sharing options...
