X14 Schedule Improvements
Joe_Carrick
In X14 we can now set Left-Right-Top-Bottom Margins for Schedules - and it's for all Cells.  In addition, we can set the Text Styles for the Title, Header & Main test of the Schedule independently from each other is also a great addition.  Make sure you set these Defaults in your Template Plans & export the Defaults so you can Import them into any existing Plans.
We finally have Schedules that are much easier to read. :wub::wub::wub:
I think fact that it s indeed for all Cells is pretty limiting. I was trying to give the Title Text a little breathing room top and bottom but keep the Header and Main Text a little tighter but no way to do one without changing them all. Not a fan but better than nothing? Would like to see the 'attribute' setting applied individually to each Title; Header; and Main text fields. Just sayin.
