Gable end fascia not showing on one half of roof
junior
3 hours ago, junior said:
This is the only roof on the plans that I can't get the trim to show.  What am I missing?
Was this done with manual roof planes?  If so are you sure that plane has the fascia settings set as the correct size?  Hard to tell from that pic but almost looks like there is a tiny fascia.
Check there first but if this is auto roofs or this doesn’t fix your issue then you will most likely need to post the .plan file (make sure you save and close Chief before you upload it.
