cbucks Posted April 23, 2022 Share Posted April 23, 2022 Sorry this is a new b question but want to remove cabinet but keep countertop and extend countertop to other cabinet counters so stool and feet can go underneath. How would I do this? Link to comment Share on other sites More sharing options...
640877262929560 Posted April 23, 2022 Share Posted April 23, 2022 Go into the cabinet drop down. Click on custom countertop near the bottom of the list. You can draw the countertop exactly how you want to Link to comment Share on other sites More sharing options...
Chrisb222 Posted April 23, 2022 Share Posted April 23, 2022 5 hours ago, cbucks said: want to remove cabinet but keep countertop and extend countertop to other cabinet counters You can also extend one of the cabinet's countertops to whatever you need: Link to comment Share on other sites More sharing options...
Kbird1 Posted April 23, 2022 Share Posted April 23, 2022 7 hours ago, cbucks said: want to remove cabinet but keep countertop and extend countertop to other cabinet counters You can also select one cabinet and click on the Custom Countertop tool on your Toolbar ...assuming X12/13 and then grab the edit handle and pull it along the bank of cabinets. Please add you SIG. so we know what Version you are using as it matters for a lot of answers. If you are using a Home Designer Product you should be over on HomeTalk as those Products can't do what Interiors and Chief Premier can...... https://hometalk.chiefarchitect.com/ you might also want to fully avail yourself of the CA KnowledgeBase ( KB) or FAQ as it's called Elsewhere https://www.chiefarchitect.com/support/database.html M. 1 Link to comment Share on other sites More sharing options...
