joestilwell95 Posted April 21, 2022 Share Posted April 21, 2022 Is it possible to draw this style of eyebrow into a roof. I can pretty well fake it with a couple of curved roof segments, but the ridge is sloped as well. Thanks - Joe Link to comment Share on other sites More sharing options...
rgardner Posted April 21, 2022 Share Posted April 21, 2022 1 curved roof plane and some messing around. Although dont recall if we had the same roof plane control for curved roofs in x10??? Link to comment Share on other sites More sharing options...
kMoquin Posted April 22, 2022 Share Posted April 22, 2022 Here's a CA video on creating the eyebrow shape: https://youtu.be/gj9eg1ekA4I 2 Link to comment Share on other sites More sharing options...
Kbird1 Posted April 22, 2022 Share Posted April 22, 2022 On 4/21/2022 at 8:05 PM, rgardner said: 1 curved roof plane and some messing around. Expand you'd need 4 curved Roof Planes for this, two each side ( opposing curves) and then join them into the main house Roof plane ....make a V-Shaped break at the Eyebrow Ridge, the break each side of the V in 1/2 , to join each of the 2 planes too. Once one side is done you can use Copy>reflect to flip the planes over the ridge tot he other side. * Kevin's Video link is a good example actually.... M. Link to comment Share on other sites More sharing options...
rgardner Posted April 22, 2022 Share Posted April 22, 2022 On 4/22/2022 at 5:35 PM, Kbird1 said: you'd need 4 curved Roof Planes for this, two each side ( opposing curves) and then join them into the main house Roof plane Expand I stand corrected but I believe you actually only need 3. @glennw taught me years ago that you can do a single radius roof plane for the center part, but you would need as you mention the concave roof planes on each side in this case. Link to comment Share on other sites More sharing options...
Kbird1 Posted April 22, 2022 Share Posted April 22, 2022 On 4/22/2022 at 6:22 PM, rgardner said: I stand corrected but I believe you actually only need 3. @glennw taught me years ago that you can do a single radius roof plane for the center part, but you would need as you mention the concave roof planes on each side in this case. Expand Yes that would work too, but I find it easier to get one side right , then just copy reflect each plane over the Ridge line and join them into the main roof. * for that particular one in the OP, 3 may work better since it is almost a Barrel with a little flare each side. M. 1 Link to comment Share on other sites More sharing options...
