Andersen Window library
BruceKC
I'm trying to use the Andersen Window catalog, and when I input the dimensions for single casements, the automatic label is the correct Andersen nomenclature.  However when I insert a twin casemenf from their library and  input the correct dimensions, the nomenclature is not the correct one.  I'm confused.  Is there a way to fix this issue?  E.G.  inputting 59.5 inches wide by 47.5 inches tall should generate the label 2640-2, but instead, it generates the label 4640.  Not sure what I'm doing wrong.
38 minutes ago, BruceKC said:
I don't know what that means?  Ruby?
Ruby is Chief's Programming Language used for Macros , Chief includes many premade ones accessed through the M in the Label tab,
but thier are a number of Forum Members who do Custom Macros though for this you should be able to specify your wanted label and start a Folder in your User Library for Andersen Windows and use them from there instead.
* Chief's Auto Labels usually round up
image.thumb.png.7517d5aaac5171867ae897c6cdf63a11.png  image.thumb.png.993d7542c63fdc7f0c69d98ec8c6eb5e.png
