Bob_Johnston Posted April 14, 2022 Share Posted April 14, 2022 Sorry if this question has been asked before but I wasn't able to find an answer. On many occasions rafters are showing through drywall and I can't figure out why. Can anyone help? Link to comment Share on other sites More sharing options...
Chopsaw Posted April 14, 2022 Share Posted April 14, 2022 Not likely to happen with auto roof. Something has been changed manually. Post the plan if you are not sure what ? Link to comment Share on other sites More sharing options...
Bob_Johnston Posted April 14, 2022 Author Share Posted April 14, 2022 That may be the case, It was a tricky roof area. Here's the plan, any ideas? https://1drv.ms/u/s!AicefBJfAFklkV0PJU9sJMdV8W74 Link to comment Share on other sites More sharing options...
SNestor Posted April 14, 2022 Share Posted April 14, 2022 @Bob_Johnston - It's a simple fix. Watch the video; Bob-Johnston - Roof Framing coming through drywall - Watch Video 1 Link to comment Share on other sites More sharing options...
Chopsaw Posted April 14, 2022 Share Posted April 14, 2022 Hi Bob, It seems that chief wants to auto frame a ridge rather than a rafter under that wall and not really sure why. 1 Link to comment Share on other sites More sharing options...
Bob_Johnston Posted April 14, 2022 Author Share Posted April 14, 2022 Hi Steve - thanks for the help. The thing that was really screwing me up was the "Roof Cuts Wall at Bottom" notation and how it prevented me from getting that attic wall in the correct position. All of the other wall issues stemmed from that - the siding and drywall on both sides worked correctly until the RCWaB was unchecked and then all hell broke loose. I know there are still a lot of details that need work on this design, I just wanted to get this issue fixed before I moved ahead. Thanks for the tips on getting the walls to join properly, I don't know how many times on a dormer situation the corners don't join up. What's worse is that everything will be fine and then out of nowhere I'll look at the exterior view and some frickin' corner doesn't have siding covering it... maddening. Link to comment Share on other sites More sharing options...
Bob_Johnston Posted April 14, 2022 Author Share Posted April 14, 2022 Chopsaw - thanks for the reply and video. I hadn't noticed that "special snapping" check box before... there are just so many little details to be aware of. I have no idea why those rafters were framed with 1x12's... I don't believe I did that (but I must have, right). Anyway, that certainly wasn't my intention. It also explains why the rafter tails of my returns were sticking down through the bottom of my eave soffit. That was driving me nuts too... I'd rebuild the roof framing and things would be fine and then I'd look later and those rafter tails would be sticking down through the eaves again. Link to comment Share on other sites More sharing options...
Chopsaw Posted April 14, 2022 Share Posted April 14, 2022 4 minutes ago, Bob_Johnston said: I have no idea why those rafters were framed with 1x12's... Yes it is odd. Some of the others were discussing it thinking it was a new problem in X14. Link to comment Share on other sites More sharing options...
Bob_Johnston Posted April 15, 2022 Author Share Posted April 15, 2022 I dunno. I'm looking at how that entire section of roof is framed and it seems very strange. I wouldn't build it like that in real life. I'm reading the X14 thread you posted and they're talking about templates possibly being a problem. This plan was started in Home Designer Pro and then I upgraded to CA 13. Do you think that could be a problem? Link to comment Share on other sites More sharing options...
Chopsaw Posted April 15, 2022 Share Posted April 15, 2022 I generally have quite a bit of cleanup to do with chief's auto framing if I am going to show it in a set of plans. As for your specific situation it is not likely that your template is responsible for the issues you are encountering but it is possible. If you run into something that no one has a solution for then you can quickly model the situation in a stock template and check. A lot of these things are known issues that have not been resolved for many versions though, and we keep hoping that they will isolate and fix the problems but some must be much harder than others. Link to comment Share on other sites More sharing options...
