VTCAD762 Posted April 12, 2022 Share Posted April 12, 2022 It's a newbie question: how I should eliminate the roof "piece/remainder" crossing the face of this dormer? What is the proper method for editing a gap in the main roof line, or cutting a "pocket" into the main roof to bypass the dormer area? Link to comment Share on other sites More sharing options...
Chopsaw Posted April 12, 2022 Share Posted April 12, 2022 Not really sure I have seen auto roof do that before but it certainly can be manually edited. Roof planes are special and you can place a break in that section and just tear out what you don't need. Or post the file and one of the experts may be able to advise how it is done with automatic settings. Link to comment Share on other sites More sharing options...
rgardner Posted April 12, 2022 Share Posted April 12, 2022 If that was done with auto roofs then that wall is marked to have a return. Link to comment Share on other sites More sharing options...
VTCAD762 Posted April 14, 2022 Author Share Posted April 14, 2022 To all who replied, thank you for taking the time to do so. I fixed it by using a trick where the dormer is framed using exterior walls to form a box inside the house, and work backward via the roof from there. It worked like a charm! Link to comment Share on other sites More sharing options...
