Project Browser Window is messed up. A fix?
robdyck
Go to solution Solved by robdyck,
The Project Browser can become undocked and then it is visible but Chief doesn't recognize it. It makes it tough to drag it back into place when Chief doesn't recognize it. Does anyone know of a fix for this?
Notice in the snippet that the PB window header has rotated to the side. I can see the PB but the cursor behaves as though it's all the plan window.
  • Solution
Solution:
  1. Close Chief.
  2. Re-open Chief. This will allow re-enable the minimize window button.
  3. Minimize the Project Browser Window
  4. Grab the Top of the PB window and carefully drag and hover until the desired docking location is actively highlighted.
  5. Release the PB window and never touch it again, intentionally or accidentally!
  • 1 month later...
Did you try resetting your side windows?
https://www.chiefarchitect.com/support/article/KB-00654/restoring-the-size-position-of-the-side-windows.html
I believe Robert's solution is only going to work in a limited number of cases and the more general reset solution should work in almost all cases.  If you are still having problems after this, then you might want to contact tech support.
