A_Joseph_PE Posted March 30, 2022 Share Posted March 30, 2022 I am trying to simply raise my SWT, while keeping the floor elevation and ceiling heights the same, but I can't seem to do that? When I change the SWT, it changes the Rough Ceiling Height, then I change the Rough Ceiling Height Back, and it drops my floor... and I continue the cycle changing values in different order to try and make it work. Does it perhaps have anything to do with my foundation values locking it? This is not specific to this house/model (it is only a shell), but I seem to be trapped in this loop often. How to modify that SWT properly and keep my other values intact? Thanks In the image below, I only want to change the values of the SWT to Ceiling and floor to SWT... Main Barn expansion_AJD.plan Link to comment Share on other sites More sharing options...
Renerabbitt Posted March 30, 2022 Share Posted March 30, 2022 21 minutes ago, A_Joseph_PE said: I am trying to simply raise my SWT, while keeping the floor elevation and ceiling heights the same, but I can't seem to do that? When I change the SWT, it changes the Rough Ceiling Height, then I change the Rough Ceiling Height Back, and it drops my floor... and I continue the cycle changing values in different order to try and make it work. Does it perhaps have anything to do with my foundation values locking it? This is not specific to this house/model (it is only a shell), but I seem to be trapped in this loop often. How to modify that SWT properly and keep my other values intact? Thanks In the image below, I only want to change the values of the SWT to Ceiling and floor to SWT... Main Barn expansion_AJD.plan 5.4 MB · 0 downloads Would be very helpful if you dropped some notes in your plan to instruct us as to where we should be looking. What room specifically are you trying to modify and on what floor? Link to comment Share on other sites More sharing options...
A_Joseph_PE Posted March 30, 2022 Author Share Posted March 30, 2022 Well... I saved the file, closed it, went back in and tried to adjust the SWT int he absolute elevations....and it worked. Must been "locked" somehow... Thanks all Link to comment Share on other sites More sharing options...
SHCanada2 Posted March 30, 2022 Share Posted March 30, 2022 I run into this all the time, and then I remember I must change the absolute elevations. which is unfortunate because then you have to do math, although the ability to just type in +1' next to the current number helps Link to comment Share on other sites More sharing options...
