KimberlySambito Posted March 29, 2022 Share Posted March 29, 2022 I imported a PDF file into Chief, copied the Kitchen and Bath Layer set and re-scaled the PDF to make it accurate. I traced the PDF, how do I remove the PDF lines so I just have my lines? Link to comment Share on other sites More sharing options...
Electromen Posted March 29, 2022 Share Posted March 29, 2022 I don't delete it, I do as Eric mentioned and create a new layer for it, then turn it off/on Link to comment Share on other sites More sharing options...
mborean Posted March 30, 2022 Share Posted March 30, 2022 I have found that PDF files really bog down Chief. I've been using the "Snip" application on windows to make a file that is much smaller. And, you can snip just the portion of the PDF you want to you don't have to deal with the entire page. Good luck! Link to comment Share on other sites More sharing options...
Kbird1 Posted March 30, 2022 Share Posted March 30, 2022 On 3/30/2022 at 1:34 AM, mborean said: I've been using the "Snip" application on windows to make a file that is much smaller Expand That works and I use it a lot myself ... but most PDF Applications , even the Free ones, have a built in Snapshot Tool which I find useful. M. Link to comment Share on other sites More sharing options...
