TennVol Posted March 29, 2022 Share Posted March 29, 2022 Inserted a shower pan from the library, drew glass walls over it and added a glass door, all from the wall and door pull downs. Viewed it in camera mode and the pan shows but no glass walls or door. Tried getting rid of the pan and leaving the walls, same. Tried changing the glass material, same. Any ideas why it won't display in 3D? Thanks. Link to comment Share on other sites More sharing options...
rgardner Posted March 29, 2022 Share Posted March 29, 2022 Do you have railing walls turned on in the 3d view layer set? Link to comment Share on other sites More sharing options...
TennVol Posted March 29, 2022 Author Share Posted March 29, 2022 Rgardner - yes, I do, but that was a good thought. Thanks. Link to comment Share on other sites More sharing options...
MoeGia Posted March 29, 2022 Share Posted March 29, 2022 Check the material settings for the glass. I don't think the out of box material shows up well in 3d standard view. If you can see it in 3d vector view, but not standard, you'll have to adjust the material settings. Link to comment Share on other sites More sharing options...
