Can I open a pocket door wider?
bdillard1
Go to solution Solved by ericepv,
1 hour ago, ericepv said:
In the 'General' tab of DBX for your door, specify 'Percent Open" in the 'General' section.
In Addition in plan view if you look close there is a grip near the end of the door and you can open it or close it however you want it to show on plan as well as in 3d (when show open in 3d is selected).
