ADallas Posted March 14, 2022 Share Posted March 14, 2022 I thought I was pretty clever. I designed an ARCH D (24x36) sheet with wide margins specifically so that I could print at 50% scale and have it fit on ANSI B (11x17), which my printer can handle. I would work on 50% reductions that were still scalable and then print commercially on 24x36 as needed. (If you're curious, you need 1-3/4" margins all around on the 24x36 if you want to fit inside 3/8" margins on 11x17.) Except that my print dialog doesn't allow me to center the 50% reduction on the 11x17 page. It aligns at the top left, and wants to use 4 tabloid pages to print 1 ARCH D drawing. It "works" if I tell it to "fit," but now my drawings are some weird scale. Is there a solution of which I'm ignorant? What does everyone else do? Link to comment Share on other sites More sharing options...
Solution Francois Posted March 14, 2022 Solution Share Posted March 14, 2022 The reduction factor will affect the design on the layout but not the size of the page which can be change in Paper Source in the Print dialog. 1 Link to comment Share on other sites More sharing options...
ADallas Posted March 14, 2022 Author Share Posted March 14, 2022 Thank you, Francois! That's the solution--can't do 24x36 at half scale on 11x17, but you can do 22x34 (ANSI D), and the wide-margin 24x36 layout that I made works just fine on 22x34. A commercial printer would just print on 24x36 if they didn't have 22x34, so the effect is just the same. Excellent. Link to comment Share on other sites More sharing options...
Gawdzira Posted March 14, 2022 Share Posted March 14, 2022 I realize that most clients you would send to would not have 12x18 paper, but, if you are printing in your office I highly recommend the Epson ET-16650, Eco Tank printer. I have 12x18 sheets printing on it. The Eco Tank is spectacular for not needing to replace cartridge's and the print quality is good. I have 2 trays for paper and then the 12x18 loads in the back on a sled. 1 Link to comment Share on other sites More sharing options...
VHampton Posted March 14, 2022 Share Posted March 14, 2022 Quote What does everyone else do? The fit to paper option works well. For an 11" x 17" 95% is usually the ideal fit. It's not to scale however, but the clients don't usually scale drawings. At least not yet anyway. 1 Link to comment Share on other sites More sharing options...
