Digger873 Posted February 4, 2022 Share Posted February 4, 2022 I am sure this has been asked before, but I cant find anything in a search, so here goes. When I create a porch with a concrete floor and post to beam, or railing a strip of wood shows through my concrete at the bottom of the wall. What am I missing here. I have tried the material painter but it doesnt work. Nothing I have tried has worked. Thanks in advance Jared porch picture.pdf Link to comment Share on other sites More sharing options...
joey_martin Posted February 4, 2022 Share Posted February 4, 2022 Are you calling that room a porch, or just changing the flooring material to concrete? Link to comment Share on other sites More sharing options...
Digger873 Posted February 4, 2022 Author Share Posted February 4, 2022 Joey, Creating a porch I assumed would be calling it a porch, using the room defintions to call it a porch, ect... No I didnt just change floor to concrete. Thanks Solver, if It was readily apparent how to include a signature I would, but after wasting 20 min trying to figure it out, I moved on to more productive things. Maybe if you included some instructions in your long list of things you think I should do/read you would get farther with the things that seem so important to you. IF your interested I'm using X13 and have used X12, X11, Chief Arch10 full version, and Chief Arch 6 full version as well. No Im not an expert, I just asked a simple question, I know how to to search and havent been able to find anything. So in the spirit of the message you just sent me dont send me messages with condesending comments and posts about how to ask questions and what you think I should do. If you have somethng to add to the actual problem Im all ears, if not, Im not interested. Thanks Jared 1 Link to comment Share on other sites More sharing options...
joey_martin Posted February 4, 2022 Share Posted February 4, 2022 @Digger873 I don't think I have even seen that happen. Does it happen every time you create a porch? Email me the plan and I will have a look. Link to comment Share on other sites More sharing options...
parkwest Posted February 5, 2022 Share Posted February 5, 2022 Check your wall type and make sure you are using exterior railing, instead of interior railing. Link to comment Share on other sites More sharing options...
Kbird1 Posted February 5, 2022 Share Posted February 5, 2022 On 2/4/2022 at 9:51 AM, Digger873 said: It was readily apparent how to include a signature I would, but after wasting 20 min trying to figure it out How too Video.....https://chieftalk.chiefarchitect.com/topic/18908-signature-here-at-chief-talk/?tab=comments#comment-155662 19 hours ago, parkwest said: make sure you are using exterior railing, instead of interior railing Tool. This is the usual problem I have found.... Use straight Deck Rail or Edge , not Straight Railing which is the interior railing. Link to comment Share on other sites More sharing options...
Digger873 Posted February 8, 2022 Author Share Posted February 8, 2022 Thanks everybody for the help. Thats what it was, The exterior railing wall type. Link to comment Share on other sites More sharing options...
