Tiny Camera views
PatriciaLiemola
I will assume that the image in the camera view is tiny.  This is usually a result of a very wide or tall model or some small object that has been placed or lost out to the side a long long way.  You can often find the object by using the "fill window" tool and then slowly turning off layers until the view is "normal" and then isolate the layer and use "fill window" again.  If you have a lot of items on the isolated layer you may need to move the known items to a temporary layer.
It is a bit of a process sometimes so if you have difficulty you can always post the plan file and one of the experts can help.
