bdillard Posted January 14, 2022 Share Posted January 14, 2022 Hello, On the bottom of CA, if I were to just drag the mouse over an area - showing a line but not actually creating a line - it would display how long that line was. This made it very easy for me to measure a distance without actually adding anything to the drawing. Can you tell me how to add back that tool or toolbar or display status at the bottom of CA? Link to comment Share on other sites More sharing options...
Dermot Posted January 14, 2022 Share Posted January 14, 2022 You can turn on/off the display of the status bar in your preferences dialog on the appearance panel. Link to comment Share on other sites More sharing options...
bdillard Posted January 14, 2022 Author Share Posted January 14, 2022 Thanks - I apologize if I'm not in the right place. I went to Edit Preferences Appearance Selected the check for the status bar and checked show screen redraw time and show coordinates and it is still not showing. I'd love to learn how to set it back but if there is an easy way to set everything back to defaults that would be fine as well. I went to toolbar customization, configureations and switch to default but that wasn't it. Link to comment Share on other sites More sharing options...
Solution GaryOhmer Posted January 14, 2022 Solution Share Posted January 14, 2022 You might not have the window in full - grab the top of the chief window and snap to the top , should restore full window Link to comment Share on other sites More sharing options...
bdillard Posted January 14, 2022 Author Share Posted January 14, 2022 On 1/14/2022 at 6:05 PM, GaryOhmer said: You might not have the window in full - grab the top of the chief window and snap to the top , should restore full window Expand OH - you are good - that was embarrassing! Thanks so much. Link to comment Share on other sites More sharing options...
GaryOhmer Posted January 14, 2022 Share Posted January 14, 2022 Usually what's obvious is the first to overlook Link to comment Share on other sites More sharing options...
