RobUSMC Posted January 6, 2022 Share Posted January 6, 2022 Is there a way to edit (rename) the different components / materials of an imported symbol. From skp / 3D WH or other users. I can assign a material to each component / part but can you change the name of that component. Like the fan I've attached. The component name is 1737467630_12footfan. I would like to name it Big Ass Fan 12'. Then the materials for this is color_255_255_255. can I rename it.... This only has one material but if it did have several of these weird named parts can I rename to Trim, Blades, Down Rod or whatever other parts it may have? Thanks Link to comment Share on other sites More sharing options...
Chopsaw Posted January 6, 2022 Share Posted January 6, 2022 Yes you can rename all those things. The Component name is the name of the Symbol so rename that in the Symbol DBX. The material name"s" can be edited from opening each and selecting the material from Plan Materials then editing it. Link to comment Share on other sites More sharing options...
glennw Posted January 6, 2022 Share Posted January 6, 2022 You can edit the Component Names directly in the dbx. Link to comment Share on other sites More sharing options...
RobUSMC Posted January 6, 2022 Author Share Posted January 6, 2022 Thanks. I was looking for an edit button or something. I didnt realize you can just double click on it to rename. Link to comment Share on other sites More sharing options...
