GeneDavis Posted December 30, 2014 Share Posted December 30, 2014 I have an as-built situation, with a plot plan of the house on paper. No CAD available. Have modeled the house in Chief and footprint matches that of the plot plan. I know how to reproduce the boundary. My problem is rotating the plot bounds and placing it so the setbacks shown on the plot plan match what is on paper, and getting my north arrow rotation right so the line bearings read true. See my plot plan, attached. None of the bounding lines of the plot are parallel to house walls. Would appreciate any and all tips, or links to how-to videos. Link to comment Share on other sites More sharing options...
dhowardaia Posted December 30, 2014 Share Posted December 30, 2014 Here's how I would do it: 1. figure out the angle between the side of the house and the 110.00' PL to the left of it. This is basic trig. Since you've got two dimensions to the house that are perp. to the PL (12.2' and 24') the B-side of the triangle is 11.8' (24.0 - 12.2) and the hypotenuse is 24.29'+35.37'. If you can't remember your highschool trig, there are plenty of online calculator that will do it for you 2. place a point marker that coincides with the corner of the back deck by using the 10.0' and 15.4' dimensions to draw lines that are perp to the side and rear PLs respectively. the marker goes at the intersection of those two lines 3. move the polygon and the marker using point-to-point move so the marker is on the corner of the deck. Now place a temporary point directly on the marker. Select the polygon and use rotate about last point to rotate the polygon so the 110' PL is parallel to the side of the house. Then use transform-replicate to rotate the polygon "about current point" the known angle you calculated in step one. Good luck, D Link to comment Share on other sites More sharing options...
Rich_Winsor Posted December 30, 2014 Share Posted December 30, 2014 There was a situation similar to this a while back. You might want to check out this thread. https://chieftalk.chiefarchitect.com/index.php?/topic/2786-what-came-first-house-or-plat-or-does-it-matter/ Link to comment Share on other sites More sharing options...
GeneDavis Posted December 30, 2014 Author Share Posted December 30, 2014 That's it. Thanks, Dorothy. And when done, I can place a north arrow along the 110' PL and since I know the PL's bearing, I can rotate north accordingly, and all the PLs can then be bearing-labeled true. Link to comment Share on other sites More sharing options...
