RobUSMC Posted December 19, 2021 Share Posted December 19, 2021 Attached is the same plan with the camera close to the same angle. Can someone tell me why in the X12 rendering has color and detail and X13 it looks washed and black and white? PB rendering is the same Link to comment Share on other sites More sharing options...
Chopsaw Posted December 20, 2021 Share Posted December 20, 2021 Wow that is quite the dramatic difference. What does it look like with the Color toggled on ? 1 Link to comment Share on other sites More sharing options...
MarkMc Posted December 20, 2021 Share Posted December 20, 2021 Link to comment Share on other sites More sharing options...
RobUSMC Posted December 20, 2021 Author Share Posted December 20, 2021 The Show Color box is checked Link to comment Share on other sites More sharing options...
Chopsaw Posted December 20, 2021 Share Posted December 20, 2021 Link to comment Share on other sites More sharing options...
RobUSMC Posted December 20, 2021 Author Share Posted December 20, 2021 Here are both plans. I backed up my X-12 plan to make sure I can still use it in X-12 then I opened the plan in X-13. Note.... I just loaded X-13 and it auto merged. Other than that I have made no settings changes. This is the first time using this version. The other thing I noticed. I tried to do a Raytrace of the same camera view in X-13 and it was extremely grainy and was nowhere near as fast as X-13. Ive seen others state they have the same issues with camera views and raytrace / PB. Are there setting changes that must be done to get what I can get in X12 or has X13 taken a step back? Zip X-12.zip Zip X-13.zip Link to comment Share on other sites More sharing options...
MarkMc Posted December 20, 2021 Share Posted December 20, 2021 IF I open a new camera in your 13 file it opens as standard with color off. after turning color on it does not refresh until the mouse is moved slightly or possibly a click insede the view Copying a PBR camera from your 12 and pasting in place in your 13 color is there but there is a difference in part since textures and symbols are missing from 12, the 13 image has ray trace off. I made some adjustments to backdrop and sun light IF you are not getting color with any of the above then check that Windows Graphic Settings are has X13 set for high performance. Link to comment Share on other sites More sharing options...
MarkMc Posted December 20, 2021 Share Posted December 20, 2021 Here is RTRT from new camera in 13, started as standard, turned on color, changed to PDB with RT. exported at just 75DPI, sun turned down to 1000, daytime backdrop 500, exposure .18, ambient occlusion at 30 1 Link to comment Share on other sites More sharing options...
