Steve_Nyhof Posted November 23, 2021 Share Posted November 23, 2021 Has anyone made this... https://www.loom.com/share/ff3cc6ce16d044f5855f2e2a406947a5 Link to comment Share on other sites More sharing options...
ACADuser Posted November 23, 2021 Share Posted November 23, 2021 Maybe one of these will help. Did not try it myself. https://chieftalk.chiefarchitect.com/topic/3537-stair-solution360-and-greater-spiral-stair-video-by-yusuf/?do=findComment&comment=30434https://chieftalk.chiefarchitect.com/topic/3706-smooth-curved-railing-video-by-yusuf/?do=findComment&comment=31829 Link to comment Share on other sites More sharing options...
Steve_Nyhof Posted November 24, 2021 Author Share Posted November 24, 2021 Thank you Sir. I will check it out. I was also thinking of trying the curved stairs as I didn’t think they could go so tight but maybe they can. I will update. Link to comment Share on other sites More sharing options...
glennw Posted November 24, 2021 Share Posted November 24, 2021 Not too hard to do with normal curved stairs and curved walls - not stair railings. Select the walls and drag the corner up and down, break the walls, etc, to get them to follow the stairs. The biggest problem with this method is that it is hard to align the bottom of the sloping walls with the lining on the underside of the stairs. But maybe you aren't showing a view from underneath. 1 1 Link to comment Share on other sites More sharing options...
yusuf-333 Posted November 24, 2021 Share Posted November 24, 2021 you can also do it using the stringers. here attached the sample plan containing it. Spir Stair solid rail.plan 1 Link to comment Share on other sites More sharing options...
Steve_Nyhof Posted November 24, 2021 Author Share Posted November 24, 2021 11 hours ago, glennw said: Not too hard to do with normal curved stairs and curved walls - not stair railings. Select the walls and drag the corner up and down, break the walls, etc, to get them to follow the stairs. The biggest problem with this method is that it is hard to align the bottom of the sloping walls with the lining on the underside of the stairs. But maybe you aren't showing a view from underneath. 9 hours ago, yusuf-333 said: you can also do it using the stringers. here attached the sample plan containing it. Spir Stair solid rail.plan 2.2 MB · 1 download Thank you gentlemen! I just sat down to give this a try. Link to comment Share on other sites More sharing options...
Steve_Nyhof Posted November 24, 2021 Author Share Posted November 24, 2021 Here is my results... https://www.loom.com/share/31e3e5d00b7c4ccf930685a6197bdc31 Not shown in the video is that I did edit other details as well. See Yusufs' example .plan above for full DBX details. Thank you! Link to comment Share on other sites More sharing options...
glennw Posted November 24, 2021 Share Posted November 24, 2021 What I don't like about this method is the faceting of the rail and no curving of the tread sides. Using a normal wall, you can use the Winders setting which gives you a smooth curve for the rail and rounded sides for the treads. With Winders checked: With Winders unchecked: 1 Link to comment Share on other sites More sharing options...
Steve_Nyhof Posted November 24, 2021 Author Share Posted November 24, 2021 11 minutes ago, glennw said: What I don't like about this method is the faceting of the rail and no curving of the tread sides. Using a normal wall, you can use the Winders setting which gives you a smooth curve for the rail and rounded sides for the treads. With Winders checked: With Winders unchecked: Very nice! So this is done with walls?! Would you please share your file? Link to comment Share on other sites More sharing options...
Steve_Nyhof Posted November 24, 2021 Author Share Posted November 24, 2021 I'm not having such good luck - LOL - still working at it Link to comment Share on other sites More sharing options...
glennw Posted November 24, 2021 Share Posted November 24, 2021 The problem with using stringers is that they can't be curved, which is causing the faceting of the rail and the straight tread sides. Here is my rough file - I deleted my original file and this is a quickie replacement. I edited the tops and bottoms of the walls in 3D views which can get a bit complicated to select the correct grips. Edit: I think you need to create a room by enclosing the circular wall around the stairs. Winders will only work in an enclosed room. Ah, and I also turned off wall caps as they don't like the curved walls. spiral 1.plan Link to comment Share on other sites More sharing options...
Steve_Nyhof Posted November 24, 2021 Author Share Posted November 24, 2021 Thank you, Sir! Here is what I have so far... https://www.loom.com/share/56a3326a09954a71a4367d0a52f89a13 Link to comment Share on other sites More sharing options...
Steve_Nyhof Posted November 24, 2021 Author Share Posted November 24, 2021 18 minutes ago, glennw said: The problem with using stringers is that they can't be curved, which is causing the faceting of the rail and the straight tread sides. Here is my rough file - I deleted my original file and this is a quickie replacement. I edited the tops and bottoms of the walls in 3D views which can get a bit complicated to select the correct grips. Edit: I think you need to create a room by enclosing the circular wall around the stairs. Winders will only work in an enclosed room. Ah, and I also turned off wall caps as they don't like the curved walls. spiral 1.plan 2.2 MB · 0 downloads Yes, the other issue with stringers is that they cannot be sized to width. Link to comment Share on other sites More sharing options...
Steve_Nyhof Posted November 24, 2021 Author Share Posted November 24, 2021 3 minutes ago, stevenyhof said: I edited the tops and bottoms of the walls in 3D views which can get a bit complicated to select the correct grips. So I see you are not using rails - ok, so working on editing grips Link to comment Share on other sites More sharing options...
glennw Posted November 24, 2021 Share Posted November 24, 2021 10 minutes ago, stevenyhof said: Yes, the other issue with stringers is that they cannot be sized to width. There is a Thickness setting for custom stringers. These are thick stringers. You can't use railings while doing the wall editing because you cannot slope the tops and bottoms of railings. 1 Link to comment Share on other sites More sharing options...
Steve_Nyhof Posted November 24, 2021 Author Share Posted November 24, 2021 Getting closer - just need to figure out the winders https://www.loom.com/share/c6dc7629518f4bada6e6389f88fe78b7 Happy Thanksgiving BTW! Link to comment Share on other sites More sharing options...
Steve_Nyhof Posted November 24, 2021 Author Share Posted November 24, 2021 5 minutes ago, glennw said: There is a Thickness setting for custom stringers. These are thick stringers. You can't use railings while doing the wall editing because you cannot slope the tops and bottoms of railings. Well, either way, I like the walls and appreciate the help!! Link to comment Share on other sites More sharing options...
glennw Posted November 24, 2021 Share Posted November 24, 2021 Can you post a cut down plan and i will have a look. That error message about the extents would suggest that you have an object floating out in space somewhere. Link to comment Share on other sites More sharing options...
Steve_Nyhof Posted November 24, 2021 Author Share Posted November 24, 2021 32 minutes ago, glennw said: Can you post a cut down plan and i will have a look. That error message about the extents would suggest that you have an object floating out in space somewhere. No hurry, it is a holiday - have a good night! Thank you, Glenn 2009.zip Link to comment Share on other sites More sharing options...
glennw Posted November 25, 2021 Share Posted November 25, 2021 Something very strange happening. If I draw the stairs counterclockwise, things aren't too bad and the ends of the treads are curved. BUT, if I draw the stairs clockwise, the inner face of the wall becomes segmented. Looks like a bug to me. Link to comment Share on other sites More sharing options...
Steve_Nyhof Posted November 25, 2021 Author Share Posted November 25, 2021 8 hours ago, glennw said: Something very strange happening. If I draw the stairs counterclockwise, things aren't too bad and the ends of the treads are curved. BUT, if I draw the stairs clockwise, the inner face of the wall becomes segmented. Looks like a bug to me. Ah! Thank you for looking into this. You know, they do offer left and right curved stairs. Maybe you are not meant to mirror a stairs if you decide to go the other direction. Not saying that is what I did, but now I want to check. Thank you for looking into this. I will report a bug if I confirm what you are saying. Link to comment Share on other sites More sharing options...
Steve_Nyhof Posted November 25, 2021 Author Share Posted November 25, 2021 So I tested both left and right curved stairs, and mirrored them and I cannot get the winders to curve with the wall. I'm going to report this to support. Link to comment Share on other sites More sharing options...
yusuf-333 Posted November 26, 2021 Share Posted November 26, 2021 Hey Here is a video showing a solid railing that follows stair. Just a railing., no need for stingers nor wall adjystment. I need some one to win this challenge before I post a "railing library objext" that you can just drag from your user library and a draw as usual. As you can see in the video the bottom height and top height can be edited in a dialog box. As you can see it can be attached to the side of the stair too. Glenn will figure out easily I am sure. 1 Link to comment Share on other sites More sharing options...
Steve_Nyhof Posted November 26, 2021 Author Share Posted November 26, 2021 51 minutes ago, yusuf-333 said: Hey Here is a video showing a solid railing that follows stair. Just a railing., no need for stingers nor wall adjystment. I need some one to win this challenge before I post a "railing library objext" that you can just drag from your user library and a draw as usual. As you can see in the video the bottom height and top height can be edited in a dialog box. As you can see it can be attached to the side of the stair too. Glenn will figure out easily I am sure. Thank you! It cuts into the ceiling correctly, but still not following how you control the bottom to follow the stairs. Still trying. This is the other way where you manipulate the walls, but cuts the ceiling... Link to comment Share on other sites More sharing options...
yusuf-333 Posted November 27, 2021 Share Posted November 27, 2021 Oh here it is, import it to your user library first. and from there you can load the railing to your stair. Solid Rail %22Follow Stair%22.calibz Link to comment Share on other sites More sharing options...
