Exterior Wall Area Calculation
HomesByDesign
Go to solution Solved by Dermot,
  • Solution
Chief's calculations are 100% accurate.   It's just that it may not be calculating things the way you want it to or expect it to.
In the case of a single default siding wall that is 10' long by 10' high, you may note that the house wrap is 100 sqft and the siding is 111 sqft.  This is because the program is wrapping the siding around the ends but it does not do that with the house wrap.  The ends take about 11 sqft more siding.
  • HomesByDesign changed the title to Exterior Wall Area Calculation
