Cabinets And Angled Walls
simonas
Actually you don't, I mean not really, rather you make them look like they fit angled walls by using filler strips (tiny cabinet objects to fill in fronts or the automatic filler option) and custom counter tops for the tops. This is actually how a cabinet person would do the actual project in the field and so it is a similar task in Chief.
If you search the old forum you will find some solutions.
My method is to use an angle front cabinet with a matching back.  Then I simply turn the cabinet around 180 degrees so the front is facing the angled wall and add a handle manually to the back.  It's really best to use a "Wall Cabinet" even for the Base Cabinet and use a PSolid for the ToeKick.
