cementlogic Posted November 11, 2021 Share Posted November 11, 2021 Is it possible to set room fill patterns to their own layer for quickly toggling off in other plan views? Link to comment Share on other sites More sharing options...
Joe_Carrick Posted November 11, 2021 Share Posted November 11, 2021 Not the "Room Fill" itself, but if you create a "Room Polyline" you can assign a Fill to that and set it to any Layer you want. IMO, the "Room Fill" should be created on the "Room Floor Finish" Layer. If that was so then in Plan View that Layer could simply be turned off when desired. That Layer is otherwise unused in the Plan View. Personally, I would prefer that the Room's Floor Finish Pattern be used as the Room Fill so I wouldn't need to actually assign a separate Fill. Link to comment Share on other sites More sharing options...
cementlogic Posted November 11, 2021 Author Share Posted November 11, 2021 15 minutes ago, Joe_Carrick said: Not the "Room Fill" itself, but if you create a "Room Polyline" you can assign a Fill to that and set it to any Layer you want. Thanks! I figured this would be the only option. Link to comment Share on other sites More sharing options...
rgardner Posted November 11, 2021 Share Posted November 11, 2021 There is a way to turn the room fill off by turning off the rooms layer, but it does cause other issues for macros and other items. Link to comment Share on other sites More sharing options...
cementlogic Posted November 11, 2021 Author Share Posted November 11, 2021 1 hour ago, rgardner said: There is a way to turn the room fill off by turning off the rooms layer, but it does cause other issues for macros and other items. Can definitely still be helpful to do it that way too, thanks! Link to comment Share on other sites More sharing options...
rgardner Posted November 11, 2021 Share Posted November 11, 2021 7 hours ago, cementlogic said: Can definitely still be helpful to do it that way too, thanks! Glad it helped. Link to comment Share on other sites More sharing options...
